RaceAnalyzer locks up
gizmodo
Post by gizmodo »
Every time I try to view the sensors in RaceAnalyzer, it locks up. I currently have TPS, RPM and GPS hooked up. I got it to work one time when I set the RPM logging to 1 hz, but it hasn't worked since. I don't have an SD card in so I can't check to see if the unit is logging, I will try that tonight.
GTIspirit
Re: RaceAnalyzer locks up
Post by GTIspirit »
gizmodo wrote:Every time I try to view the sensors in RaceAnalyzer, it locks up. I currently have TPS, RPM and GPS hooked up.
Try it with the "GPS Installed" box unclicked. I noticed that my sensor live view also froze after I clicked the "GPS Installed" box and tried sensor live view, with the same configuration that previously worked, except for the GPS installed box. I didn't have time to make a config change download and try this theory, so please report back if this fixes it for you or not.
Hi Gizmodo,
what version of windows are you running? is it XP? We have seen reports of Windows XP users seeing a lock-up on the data monitoring screen.
gizmodo
Post by gizmodo »
I am using Windows7 32 bit.
32 bit windows 7. check. time to fire up a VM!
gizmodo
Post by gizmodo »
Is there anything I can do to help? I'm a software engineer. Mainly web and desktop, but I do have experience with embedded as well.
gizmodo
Post by gizmodo »
I can confirm unchecking this box fixes the problem.
