No data shown at RC.com
ZeeB
Post by ZeeB »
So I managed to get a t-mobile card and went for a test drive tonight. All the lights indicate that things should be working, I have a cell signal etc. But logging into the website my device never showed as being connected. Suggestions on how I can trouble shoot further?
Guys
Hi Zeeb,
When you were logging, did you notice the Ttransmit / Receive lights flashing on the Real Time unit? The Transmit light is on the upper left. When connected and logging to the site, it will flash rapidly and regularly.
http://autosportlabs.net/RaceCapturePro ... ceive_LEDs
Also, did you reduce your logging rates to match the recommendation in the telemetry quick start? The default accelerometer settings of 30Hz is a bit too fast for the cellular connection.
ZeeB
Post by ZeeB »
Thanks Brent, it looks like I had my sample rates too high. I'll update those and give it another try.
Nick
ZeeB
Post by ZeeB »
Hi Brent,
I tried again with lowered data rates and I am still not getting realtime telemetery. I am getting data logged by the RCP to my SD card. I get the 3 second flash for an active connection.
On the TX and RX lights I seem to get some paired flashes, and a few blips of TX but nothing steady.
Suggestions welcome.
Thanks for working through this. So I would double check the device Id you have registered on the site and make sure it matches exactly what you have programmed in RCP by reading it with RaceAnalyzer.
If youre still having problems after checking that, drop us an email at RaceCapture@Autosportlabs.com . we will get it squared away!
