1-wire gear position sensor for cars: Critique my circuit
GameboyRMH
Post by GameboyRMH »
I got this idea after hearing of the very convenient factory sensor on neoraptor's bike. Here's the circuit:
The switches are magnetic and can be triggered by the shifter itself or the levers on a transaxle (so they're mechanically locked out such that only one can be closed at a time). The resistance values here should give a ~0.5v difference in the signal between gears. Looks good?
dimondjack
Post by dimondjack »
Yep, but I think you'll get less than a 0.5v difference per gear. My quick calcs said that you are closer to 0.4v for the first three. You could adjust your resistor values to make it exactly 0.5v if you are interested in that.
That said, you'll be fine with this setup.
GameboyRMH
I'm interested, what resistance value did you use in the calculations?
dimondjack
I just did the very rough calcs (I did them on paper, didn't get to a second decimal) previously. Here are the full calcs as I see them:
1- 5v - 1.5/16.6*5v = 4.55v
(delta of 0.38v)
2 - 3/18.1*5v = 4.17v
(delta of 0.32v)
3 - 4.5/19.6*5v = 3.85v
(delta of 0.27v)
4 - 6/21.1*5 = 3.58v
(delta of 0.25v)
5 - 7.6/22.7*5 = 3.33v
(delta of 0.2)
Rev - 9/24.1*5 = 3.13v
To solve for the resistances to get you a desired voltage, you can use:
Req. resistance = (15.1*(5-DV))/(DV)
Where DV is your desired voltage.
dimondjack
I just edited my post; I was doing a shortcut and all of my formulas were for the desired voltage drop. I changed it all to be the voltage you want the system to actually read.
GameboyRMH
Thanks, my electronics experience is mostly digital. My only experience with analog circuits is making power supplies for the digital circuits :P
Recalculated resistor values:
dimondjack
Looks good! You should get a nice 0.5v drop for each gear.
This is great! Could we add this to the wiki?
dimondjack
Brent,
Are you referring to the sensor information (model, etc), or the information on how to calculate voltages (my replies)?
I was referring to the whole thing. Also need to review neoraptor's sensor information.
GameboyRMH
Hey, sorry that I missed your replies! Yes feel free to add this to the wiki.
