Obviously if it connects via Bluetooth it needs to be able to up/down-load map data.
The advance matrix (bunch o' bins) needs to expand with the window.
The window needs Hot Buttons to start a quick log and to mark a position (simulated space bar). No keyboard on a tablet.
All the main buttons need to be big enough to use with a finger tap on a tablet or smartphone.
There should be a preference that the user can set to make the quick log function either create dated logs (as is currently done) or create one generic log that is overwritten each time a log is recorded. This is mainly to save on the storage requirements which may be scarce on a tablet or a smartphone.
It would be nice if the program were more tolerant of having the COM port set wrong.
Suggestions for MJLJ or MJ2 Configurator software.
- Contact:
