MJ with external map sensor
wld
Post by wld »
Hello.
I've tried searching around the site and forum, but couldn't find an exact answer to my problem.
I've got a carburetted engine, which I am hoping to feed with between 30-35 psi of boost. In order to do this I'll need an map sensor wich accepts 4 bar.
The way of doing this is what I understand; purchasing MJ prepared for TPS, then an external map sensor. Using the load axis calibration, I'll have to put in the values for my 4 bar sensor.
Is this possible?
Regards
Henrik
wld
Post by wld »
Oh, and how do i hook up the map-sensor?
/Henrik
