Pulse/RPM divider limitation
mauclair
Post by mauclair »
just install V2, good work.
When reconfiguring the setting in the pulse/RPM, I was not able to go with a divider higher then 6(max option that It seem to have in the interface), in my case I need to 42. Did I miss a way to enter it direcly or is it max 6?
thanks
Thank you. Do you mean the pulse per revolution field?
mauclair
Post by mauclair »
Yes the pulse per revolution field , I just saw the "7", cut in half at the bottom of the interface screen, there does not seem to be a scroll bar or something similar to access possibly more choice.
Try clicking and dragging the list up and down. Also, try using the mouse scroll wheel or do the two finger drag on a laptop's trackpad, if applicable.
mauclair
Post by mauclair »
LOL, that was easy :) , did not have a mouse on the laptop, working good.
