Tach signal from MJ
Billy C
Tach signal from MJ
Post by Billy C »
I'm having trouble getting a solid tach signal form my Mega Jolt. The tach I have on the dash works fine but the RaceCapture doesn't seem to like it no matter what software settings I choose for it. Just gives me really erratic readings. Maybe this isn't a software issue but figured I'd have to start somewhere
-Billy C
Hi Billy,
What tach signal are you using from the Megajolt to drive it?
Billy C
Post by Billy C »
Just splitting the one to the tachometer. So from the MJ tach out to the tachometer and racecapture's input. Just put a scope on it this weekend and am seeing 2v square wave. No noise at all.
-Billy C
Can you test it without the tachometer attached? you should be seeing a square wave larger than 2v... this is a bit odd.
Billy C
Post by Billy C »
No problem.
-Billy C
