VRef and TPS Sensor Question
bladerunner80
Post by bladerunner80 »
Can I use the VRef and Negative pins on the megajolt box to power my TPS sensor for my air/fuel meter? I'm installing a TPS sensor on one of my carbs to use with my Innovate LM-2 and I read the VRef pin on the MJ box provides a 5v power lead which the TPS sensor needs. I'm assuming the TPS sensor drawing power from this pin wouldn't interfere with the MAP sensor operation (I'm using the MPA sensor for ignition)?
Absolutely. You can totally use the Vref pin as a source of power for the TPS sensor.
bladerunner80
Awesome, thanks!
