Can megajolt E be installed without a TPS
Bowood14
Post by Bowood14 »
My first post of many! I have been offered a megajolt E to fit to my 2.0 zetec with twin 48 webers but they don't have TPS. I know I could fit one but Is it possible to use this megajolt E with crank sensor and edis only as I understand the megajolt jr works. Any help would be gratefully received Thanks Adrian
Alex B
Post by Alex B »
Yes, but you get a very 2-dimensional performance. Only parameter that changes timing is rpm, load is constant so you end up with advance as programmed in the nill-load row. Not quite a performance boost.
Alex
Bowood14
Post by Bowood14 »
Thanks I have now worked out I can fit a TPS quite easily so will be😃 is there an idiots wiring guide anywhere for Zetec I have edis, TPS, crank sensor, coil all to be wired into megajolt E
Alex B
Post by Alex B »
In the "How-To" department of this website you'll find everything you need to know. I am not too Ford familiar, was Zetec still dizzy operated or did it have Edis?
Alex
The alternative for measuring engine load is by using the MAP sensor option instead of TPS- this is the most popular option. The MAP sensor connects to your intake manifold using a length of vaccum line. All documented in the megajolt installation guide.
Hope this helps - let us know if we can help further.
Bowood14
Post by Bowood14 »
All done much easier than expected but had to think about it Preparation was the key!!
Awesome, thanks for the update!
