ignition starts from or ends at?
Ivan
Post by Ivan »
When you fil in the amount of degrees advance in the first cullum and you have
for instance 900 rpm, does this mean that it wil run this amount advance up to 900 rpm
or does it work starting at 900 rpm the amount of advance?
If it is starting from, then you schould start with 600 rpm because the next
cullum starts again from ... rpm.
Am I making sense at all?
ivan
4600cc
Col 1, Col 2, Col 3, Col 4 1
Post by 4600cc »
1000 , 2000, 3000, 4000
At 500 rpm timing will be that of located under Col 1.
At 1500 rpm timing will be that of located under Col 1.
At 1900 rpm timing will still be that of located under Col 1.
At 2000 to 3000 rpm timing is that of located under Col 2.
At 3000 to 4000 rpm timing is that of located under Col 3.
At 4000 rpm and above timing is that of located under Col 4.
