Pulling the trigger
jottofar
Pulling the trigger
Post by jottofar »
So looks like I am pulling the trigger on the RCP with obd2 cable and bluetooth to use with Solo storm. I drive a US 2009 mazda mx5 and my big question is will the RCP using the OBD2 cable pick up on the stock brake sensor and steering angle sensor from PID list.
And my next question is will the SD card still record data if I am using bluetooth to interface with solo storm. Thanks
info on solo storm
http://www.petreldata.com/product/solos ... o-package/
jonesy
Post by jonesy »
Just bought the same setup myself for a BRZ, also looking for steering angle and brake sensor output through OBDII/CAN but no luck so far. I am not a computer guy so this is looking pretty intimidating if I can't pull these from the OBDII cable.
jottofar
Post by jottofar »
jonesy wrote:Just bought the same setup myself for a BRZ, also looking for steering angle and brake sensor output through OBDII/CAN but no luck so far. I am not a computer guy so this is looking pretty intimidating if I can't pull these from the OBDII cable.
Hello Jonesy could you share with me what automatically came up ?
Thanks for your interest!
We have it on the list to enable custom OBD-II pids - we have the infrastructure to support it is in place; most of it is to expose it in the app's user interface.
Also, yes - you can record to SD as well as transmit data over bluetooth.
Any other questions, let us know!
jottofar
Post by jottofar »
brentp wrote:Hi,
Thanks :) My order has been shipped so hoping to have it in hand soon so I can start testing.
jonesy
Post by jonesy »
I am getting readings for:
RPM
TPS
Fuel Level
Engine Temp
Engine Load
Battery
Also, ask Mike at Petrel to add you to the beta list for the new software version, RCP wouldn't talk to solostorm with the current release. Successfully got the basics working today with solostorm using the beta release (GPS, accelerometer/yaw sensor, RPM, TPS).
jottofar
Post by jottofar »
RPM
TPS
Fuel Level
Engine Temp
Engine Load
Battery
Thanks for posting. I have been emailing with Mike but he never mentioned any of this. I will have to follow up with him.
