Error light on when attempt to log
radixms
Post by radixms »
Hello, attempted to use the MK2 this past weekend, but when ever I pressed the log button the error light would come on.
I could not find a simple explanation on to view the error log, so before I spend some time and in an effort to save time.
How do I view the error logs?
I did not have a tablet or PC attached the RCP MK2, just attempting to log to review later.
Thanks .
toga94m
Post by toga94m »
Does your SD card have a write-protect switch that might have slid when the card went into the RCP?
radixms
Post by radixms »
The Micro SD cards, at least the ones I have, do not have lock switch.
Do the cards need to be prepped for use with the MK2?
How can do I look for the error that it is blinking for?
what size card are you using? Ensure it is 32GB or less. Also, you might want to give it a fresh format in your computer.
