Hall effect to digital input and about outputs
lofty
Post by lofty »
Im considering RCP and have some questions. Can the digital input/outputs be configured for hall effect signal from at least the two front wheel ABS sensors? I plan to use 2 of the pulse inputs for vss and rpm. Can I configure one of the digital or analog outputs to reproduce or mirror the vss input signal?
As a matter of interest what are folks using the output channels for?
if you want to measure RPM or frequency then you'll want to connect the sensors to one of the timer input channels; the general input/output channels are not designed for high speed signals (more like reading switches or other slow state).
Most people use the input and outputs with the Lua scripting capabilities to customize behaviors. Examples here:
http://autosportlabs.net/RaceCapturePro_Lua_Scripting
