A simple solution for using after market rev limiters and sh
Josh_b
Post by Josh_b »
After a bit of tinkering i have found a simple way of using afer market rev limiters and shift lights. Here is how:-
1.Make up the diode tach adapter circuit ( the origional one, not the modified one.
2.Connect a 5k resistor (or there abouts, anything more than 1k seems to work)from the output of the diode circuit, to your earth supply. probably best to use a 1watt?
3.connect your shiftlight/rev limiter (the wire that would normally go to the coil) to the diode circuit output, (its also the place where you connected one end of the resistor to)
4.hopefully it should work, well it does for me,
comments etc welcome
