Extended Can not working for me..
mach1000
Post by mach1000 »
Hi guys,
I am having a issue with the lua can bus function. It works perfect with 2.0 a protocol, but as soon as I switch to extended mode it doesnt transmit the correct ID. It sends 0x00 no matter what I do.
I have to be able to transmit in 2.0b mode since it is speaking with a propriatary protocol so therefore I can t use standard protocol.
Any other have same issues? I am running newest firmware and App.
Best regards
Mads
Hi Mads,
We will double check the extended IDs and get back to you.
we will have this fixed in the upcoming 2.8.4 release, available next week.
-Brent
mach1000
Post by mach1000 »
Perfect Thank you :)
imstimpy
Post by imstimpy »
Was this fixed? I'm having issues reading data after an extended ID transmission. I get a successful write but rxCAN always returns a nil id. I don't have VehicleSpy hooked up to see what is actually going out on the line.
Hi, we are targeting this fix for 2.9.0 firmware, along with a bunch of other fixes and improvements, but we have made a beta 2.8.7 firmware that has only this fix we're testing. If you're willing to test it out, we can make it available.
imstimpy
Post by imstimpy »
I'm in a great position to test it. My script is written to write and read 29-bit; I have external application code, other hardware, and Vehicle Spy to test.
2.8.7 firmware released here, which should fix your CAN ID issue:
https://www.autosportlabs.com/2-8-7-fir ... has-moved/
imstimpy
Post by imstimpy »
I'll test it out as soon as I can. My tests will be through LUA custom block reads over extended CAN.
imstimpy
Post by imstimpy »
I can confirm that 29-bit CAN is indeed working on 2.8.7+.
Thanks for the update!
