MAP Connection
Dazman1360
MAP Connection
Post by Dazman1360 »
On a recent Rolling Road session the guy working on my car moved the MAP sensor tube from a take-off on the inlet manifold and put it on the vacuum connection on one of the carbs. I questioned this as MJ installation instructions says not to use the carb connection, he said in his experience it works better this way.
Should I leave the tube on the carbs or move back to the manifold?
So long as they provide a stable, smooth vacuum reading it should be fine. You can attach a manual vacuum gauge to the new location and watch for any pulses under varying RPMs.
Dazman1360
Thanks Brent, will get a vacuum gauge and test it.
