Hi everyone,
Maybe this question is extremely dumb and I miss something obvious, but could you please help with the info about how to connect the sensors (i.e. where exactly should each of 3 sensor wires wire go)?
Thanks in advance!
Wire scheme for connecting Hall sensor (and others as well)
Are you looking for a wiring diagram? Here is the documentation for sensors. http://autosportlabs.net/RaceCapturePro_Sensors If you go to the "Wheel Speed / Gear speed" they mention the use a of pull-up resistor.
