no fire, or tach
arlanfalk
no fire, or tach
Post by arlanfalk »
hi, i am installing this on a sbf 5.0, i have an 97 mountaineer balancer with the timing marks and
using the crank sensor,
i have the two coil packs of the megajolt website.
ive tried two different edis-8 controllers and 2 different kps's . and still no luck
to troubleshoot i guess you can run the edis-8 without hooking up to the megajolt and it should run at 10deg (limp home)
are these crank position sensors compatibile? any ideas?
thanks
Apologies for the late reply. You should definitely use the Ford VR sensor for best operation.
Here is a handy reference for verifying voltages: http://autosportlabs.net/MJLJ_V4_vehicl ... tion_Steps
Yes; the EDIS module will control the engine in the default 10 degrees 'limp home' mode.
Please let us know the latest on your testing!
