Lap timing trouble, is it just me?
adam
Post by adam »
I've never been able to get lap timing working on multiple occasions at 2 different 'automatic' tracks. So I'd like to get it sorted at home while doing a circuit around my house (my neighbors already think I'm nuts)
here is a screen cap of my GPS data
I dont know why the Longitude displays that way, it just does.
I enable manual race track, set a start/finish using the GUI button. write to the RCP, then do laps.
interval, GPS and distance all change. but laps never do.
What do I need to do to test the lap timer without wasting more expensive track time?
Hi Adam,
Let's start off by base-lining your configuration. What firmware and app are you running?
Also, if you want to email us or me your configuration, we can take a look at it to make sure it's correct.
Also also, watch the behavior under the system status (touch menu at the top, System Status): If you set a manual start/finish line, and then drive through it, and then again, you should see the states of "In Lap" change once you cross the start/finish line the first time. In addition to that, CurrentLap should increment.
I'm assuming you're following this procedure for setting the start/finish line:
* Waiting for GPS to be warmed up and fully locked on (high number of GPS satellites) so your position is stabilized: 30 seconds to 1 minute of clear sky after power on.
* Rolling up to your start finish line and pausing.
* Reading the current RCP configuration
* Setting RCP config to 'manual start/finish' and disabling 'separate start/finish lines' setting.
* Pressing the target icon, which updates the start/finish line fields with the current coordinates
* Writing the config back to RCP to set the start/finish line
Let us know what you find out and we'll get you sorted!
adam
Post by adam »
Firmware is current 2.8.4
Android app is 1.3.9
emailed my config
followed your instructions above and still no laps. I checked system status and it never indicated that it was 'in lap'
GPS sample rate set to 10hz
I dont suspect its my physical setup, but here are pics anyway.
antenna on roof
Hi Adam,
can you post an update on your recent testing results? I think we got it working for you, just wanted to confirm.
adam
Post by adam »
I'm all set and good to go now. The new firmware and app update did the trick.
I had a little hiccup at the track with my script not carrying over but Andrew (your programmer?) got me sorted out at our mutual race.
Thanks for the support!
