Can I run the mjlj with out the MAP sensor
mrknighty
Post by mrknighty »
Is it possible to run the Megajolt lite system without the MAP sensor (for the time being) if so how would i go about doing this, do i need to just set the MAP bins to zero???
Do you have a unit with the
Do you have a unit with the map sensor installed already? If that's the case, and it's not connected to your engine, you can 'box in' the atmospheric pressure range in your ignition curve.
The sensor unconnected will show around 100KPa, which is atmosphere.
You can put two rows in the table - 90 KPA and 110KPA; the ignition controller will be locked in within this range.
Hope this helps,
mrknighty
thanks
Post by mrknighty »
thanks alot will give that a try, I just what to set it up roughly til I can get it booked in for a tune on the rolling road.
