I am looking to fit the MegaJolt system to my A-Series turbo engine, just wondered if anyone else has fitted the system to an a-series, either turbo or N/A. Does anyone have a base map for it. What MAP sensor will i need for a turbo charge setup, i will be running upto 20psi of boost pressure. Any help would be much appreciated.
Luke
Megajolt on A-Series Engine
im using the megajolt on a turbo
the map sensor is built into the unit and the std one works fine
ive ran 16psi on mine so far with no problems
let me know your email and i will send you a copy of my map (up to 12psi) but works fine further on
any chance i could get a copy of that map! i'm currently building a mini turbo, hopefully ready for the mini showndown in july but i'll see how the work go's, i have alot to do to be ready, i'm going to use megajolt, i got mine from martin milliner, top chap!
my email is clubminiflip@aol.com, chhers
If you head over to Turbo Minis ( http://www.turbominis.co.uk/ ) and have a search there's a wealth of info there. Quite a lot of the turbo guys run megajolts.
