Firmware 2.10. and 2.10.1 has a problem with WIFI via LUA
Rainer
Post by Rainer »
Hi ASL-team,
I fear the new firmware has a problem with contolling the WIFI module via LUA although I disabled all WIFI switches in the HMI (as Brent suggested). While the connection to a network works, sending or receiving of data won't. With the 2.9.2 firmware it works perfectly fine. As basis for the test I used the GOPRO script.
It seems to me that the eventually recieved and sent data is not read/sent as a string but as integer. I tried to spot the difference in your source code, but after this monster merge - it's hard to find.
What I can say is that if I change in LuaLoggerBinding.c:
lua_serial_write_char: lua_tostring to lua_tonumber (as it was in 2.9.2) and
lua_serial_read_char: lua_pushlstring to lua_pushnumber
than it works providing the lua skript is adjusted.
Thanks for checking.
BTW.: I'm quite sure it's the same problem as JJLudemann has "2.10.0 Firmware Won't Print(integer)"
Hi - we'll take a look at this and get back shortly!
stieg
Post by stieg »
Andrew Stiegmann (Stieg)
Principal Engineer
Autosport Labs Inc.
Rainer
Post by Rainer »
Thank you Brent, thank you Stieg,
I can't stress enough how much I enyoy working with your great product.
Both thumbs up,
Rainer
