What am I doing wrong on this lua, reading the logs I see the built in Speed|"mph"|0.0|150.0|252 with data in it, I'm not sure what that comes from
but none of my additional columns like SPEED_MPH and SPEED_KPH have anything in them
--This example configured for Mini Cooper CAN
-- Automatically starts logging with engine 'on' (RPM triggered)
--how frequently we poll for CAN messages
tickRate = 30
--the CAN baud rate
CAN_baud = 500000
--CAN channel to listen on. 0=first CAN channel, 1=second
CAN_chan = 0
--add your virtual channels here
--format addChannel(<name>, <sample rate>, <precision>, <min>, <max>, [units])
tpsId = addChannel("TPS", 10, 0, 0, 100, "%")
tempId = addChannel("EngineTemp", 1, 0, 0, 255, "C")
oilTempId = addChannel("OilTemp", 1, 0, 0, 255, "F")
rpmId = addChannel("RPM", 10, 0, 0, 10000)
steerId = addChannel("Steering", 10, 0, -360, 360, "Deg.")
brakeId = addChannel("BrakeSw", 10, 0, 0, 1)
brakePressId = addChannel("Brake", 10, 0, 0, 255, "Bar")
clutchId = addChannel("Clutch", 10, 0, 0, 1)
--lfWheelId = addChannel("LFWheelSpd", 10, 0, 0, 200, "MPH")
--rfWheelId = addChannel("RFWheelSpd", 10, 0, 0, 200, "MPH")
--lrWheelId = addChannel("LRWheelSpd", 10, 0, 0, 200, "MPH")
--rrWheelId = addChannel("RRWheelSpd", 10, 0, 0, 200, "MPH")
--gearTempId = addChannel("GearboxTmp", 10, 0, 0, 400, "F")
fuelId = addChannel("Fuel", 1, 0, 0, 100, "%")
extTempId = addChannel("ExtTemp", 1, 0, 0, 120,"F")
SpeedID = addChannel("Speed",25,2,0,150,"MPH")
SPEEDMPHID = addChannel("SPEED_MPH",25,2,0,150,"MPH")
SPEEDKPHID = addChannel("SPEED_KPH", 25,2,0,200, "KPH")
SPEEDGPSID = addChannel("SpeedGPS",25,2,0,150, "mph")
--Convert C to F
function toF(value)
return value * 1.8 + 32
end
--TPS, correct your throttle here for true 100%
function tpsFilter(value)
return value + 0.0
end
--only start logging / telemetry if engine is running
function rpmFilter(value)
if value > 500 then startLogging() else stopLogging() end
return value
end
function brakeFilter(value)
return bit.rshift(bit.band(value, 0x10), 4)
end
function clutchFilter(value)
return bit.band(value, 0x01)
end
function processWheel(id, data, offset)
--wheel speed is 13 bits long, little endian
--low byte high byte
--76543210 76543210
--11111111 11111XXX
local highByte = bit.band(data[offset + 2], 0x1F)
local lowByte = data[offset + 1]
local value = highByte * 256 + lowByte
value = value * 0.0625
--convert to MPH. comment to keep KPH
value = value * 0.621371
setChannel(id, value)
end
function processSteering(data)
local steer = 0
if data[2] > 127 then
steer = -1*(((data[2]-128)*256)+data[1])
else
steer = (data[2]*256)+data[1]
end
setChannel(steerId, (steer*0.045))
end
function fuelFilter(value)
--adjust for 7 bit value
value = bit.band(value, 0x7F)
--convert liters to %
return value / 0.48
end
function extTempFilter(value)
local temp = bit.band(value, 0x7F)
if value > 127 then
temp = -1 * temp
end
temp = toF(temp)
return temp
end
--customize here for CAN channel mapping
--format is:
--[CAN Id] = function(data) map_chan(<chan_id>, <data>, <CAN offset>, <CAN length>, <multiplier>,
-- <adder>, [filter])
CAN_map = {
--[496] = function(data) processWheel(lfWheelId, data, 0)
-- processWheel(rfWheelId, data, 2)
-- processWheel(lrWheelId, data, 4)
-- processWheel(rrWheelId, data, 6)
-- end,
[339] = function(data) map_chan(brakeId, data, 0, 1, 1, 0, brakeFilter) end,
[504] = function(data) map_chan(brakePressId, data, 2, 1, 1, 0) end,
[809] = function(data) map_chan(tpsId, data, 5, 1 , 0.392156863, 0, tpsFilter)
map_chan(tempId, data, 1, 1, 0.75, -48)
map_chan(clutchId, data, 3, 1, 1, 0, clutchFilter)
end,
[1349] = function(data) map_chan(oilTempId, data, 4, 1, 1, -48, toF) end,
[1083] = function(data) map_chan(gearTempId, data, 0, 1, 1, -55, toF) end,
[790] = function(data) map_chan(rpmId, data, 2, 2, 0.15625, 0, rpmFilter) end,
[501] = function (data) processSteering(data) end,
[1555] = function (data) map_chan(fuelId, data, 2, 1, 1, 0, fuelFilter) end,
[1557] = function (data) map_chan(extTempId, data, 3, 1, 1, 0, extTempFilter) end
function onTick()
setChannel(SpeedGPS, getGpsSpeed())
setChannel(SPEED_MPH, getGpsSpeed())
setChannel(SPEED_KPH, getGpsSpeed() * 1.61)
setChannel(Speed, getGpsSpeed())
processCAN(CAN_chan)
end
--===========do not edit below===========
function processCAN(chan)
local msg = 0
repeat
local id, e, data = rxCAN(chan, 0)
if id ~= nil then
local map = CAN_map[id]
if map ~= nil then
map(data)
end
end
msg = msg + 1
until id == nil or msg > 100
end
--Map CAN channel, little endian format
function map_chan(cid, data, offset, len, mult, add, filter)
if offset + len > #data then return end
offset = offset + 1
local value = 0
local shift = 1
while len > 0 do
value = value + (data[offset] * shift)
shift = shift * 256
offset = offset + 1
len = len - 1
end
local cv = value * mult + add
if filter ~= nil then cv = filter(cv) end
setChannel(cid, cv)
end
initCAN(CAN_chan, CAN_baud)
setTickRate(tickRate)
