New MJLJ not turning on?
mattsmadmini
Post by mattsmadmini »
Currently trying to get my turbo moke going, have edis module correctly wired, have minimal wiring set up for MJLJ in place ie. 12v, ground, pip and saw.
This is a new unit purchased 6 months ago, no indicating green light is turning on, and im not sure that the MJ maps are even working, will have to plug in laptop in the morning to find out.
Any help with this would be awesome, thanks
If you don't get a power on LED or PC communications after applying power to the correct pins on the molex connector (you can bench-test with a 9v battery) then the system might need to be looked at. Let us know how we can help!
