RaceCapture/Track GoPro triggering supported?
WhatsADSM
Post by WhatsADSM »
It appears that RaceCapture/Track should have everything required to trigger a GoPro along with the datalogging, however I wanted to verify. Is this correct?
Bryan@UnderbiteRacing
Post by Bryan@UnderbiteRacing »
Hi -
I'm using the RaceCapture/Pro Mk2 and the wifi module - with that combo, I'm able to use Lua scripting to trigger the GoPro during each session. I'm using RPM as the variable to trigger data logging / video recording.
Hope that helps!
Cheers,
Bryan
Right now GoPro triggering is supported only under RaceCapture/Pro and RaceCapture/Apex with Lua scripting.
https://wiki.autosportlabs.com/RaceCapt ... _GoProWiFi
Next firmware version we'll be supporting it fully within the firmware, and will include support across all version of RaceCapture, including RaceCapture/Track. Tentative timeline for that is April / May.
Hope this helps!
GTIspirit
Post by GTIspirit »
How about Garmin Virb Ultra 30 trigger? Sounds better for automotive with OBD2 support.
https://www.dcrainmaker.com/2016/09/gar ... eview.html
Cool - I'm sure someone could whip up a script in the style of the current GoPro script.
