FRS / BRZ OEM PID support
Another popular one - this thread tracks OEM specific PIDs for the Toyota FRS / Subaru BRZ platform. Post here on any knowledge or research you might come across.
Great idea for a thread, the FRS/BRZ/GT86 really needs this as it has the oil temperature buried in the OBDII.
I'm not sure how this relates to the racecapture but for the Torque app apparently this is the PID setting for oil temperature
OBD2 Mode and PID: 2101
Minimum Value: -40
Maximum Value: 215 (this is just the maximum that this location can support, which does not mean the sensor can read that high)
Scale factor: x1
Unit type: C
Equation: AC-40 (no space between A and C; "AC" is the location within the response)
OBD Header: 7E0
Would be great if someone could tell me how to set this up on my racecapture as it's the primary reason I bought it for my GT86 Racecar. Does the latest version of the app now let you customise the OBDII PIDs?
Minimum Value: -40
Scale factor: x1
Unit type: C
OBD Header: 7E0
My biggest fear is when I die my wife will sell may cars and parts for what I said they cost
Thanks for that. The combination of the 2.11.0 firmware (releasing this week) and the 1.9.0 software allows the customization of OBDII PIDs on top of the built-in support for SAE standard channel presets like RPM, TPS, EngineTemp, etc.
This week we'll also be updating our OBDII guide to illustrate how this works.
so the new firmware is out and I am keen to get this working with some custom BRZ PIDS,
oil temp and brake pressure are close to the top of the wishlist.
Attached is the data i've found but will need to put it into recapture correctly. That's where i need help!
- 86 Standard PIDs.pdf
- (130.04 KiB) Downloaded 1179 times
Hi! So, those look like SAE standard OBDII PIDs - didn't see any OEM specific (mode 22) PIDs in there.
You can map these by creating a new OBDII channel, and setting the mode, PID and the proper conversion formula.
We have pre-set OBDII PIDs for the SAE standard channels we feel people would be most interested in- all you have to do is select it and all the other settings are pre-populated.
If there's another PID not in our dropdown list, try making a custom mapping and see if that works.
Post your testing results here!
You are correct Brent, yes that list was the standard ones, some of they may be handy but really the oil temp is the one I imagine we all want, and it wasn't in there anyway!
All I have is the info same as above:
PID 2101
Min -40
Max 215
Scale x1
Unit Type C
Equation AC-40
OBD Header 7E0
Just not sure if or how this can be used with RC
maybe not supported as above?
PID 2101
Min -40
Max 215
Scale x1
Unit Type C
Equation AC-40
OBD Header 7E0
