Why are my sessions starting and stopping so often?
Used the RCP for the first time a month or so ago.
Installed a [very small] LUA script so that it would auto-start logging.
From ~5 hours of track time from 5-6 actual sessions, I have no less than 42 log files with on-track data. 127 files if you count the time it was sitting in the pits being turned on/off while servicing.
From the 42 log files, the vast majority of them have no more than 1 complete lap - many have just a portion of a lap. Most have a portion of a lap, a full lap, then a portion of another lap. I have not found a single session with more than 3 complete laps, though I haven't yet opened all of them (I've probably been through half of them).
FTR: In reality, the first two sessions were ~2 hours each, then the remaining 3-4 sessions were 20-30 minutes each. This was at Thunderhill near Sacramento - using the full 5 mile track. The GPS antenna is mounted to the center of the roof of the car - close to the windshield.
With that, any idea why it kept starting/stopping so often? I'm happy to upload the 42 log files with data (about 9MB zipped) if it helps
Can you share your script so we can see how it's designed? Also, what firmware is being reported?
Across a sampling of your log files, if you open them up in a text editor, do you see the interval column starting again from a low number, or do they all keep incrementing? A reset interval will indicate the system is resetting somehow.
Resetting would show up as a temporary interruption of LED activity on the front panel as well, if you were to test around the block or do a static test.
The LUA script in question is this one: https://wiki.autosportlabs.com/RaceCapt ... Powered_On (FWIW, Ryan D was there and helped us get auto-logging working)brentp wrote:Hi,
I just went out to the car to confirm. It looks like spacing is a little different (not sure if whitespace matters in LUA). This is exactly what's displayed under "Scripting" in the app:
Code: Select all
function onTick()
startLogging()
end
Interval is the first column, yes? Seems pretty consistent.Across a sampling of your log files, if you open them up in a text editor, do you see the interval column starting again from a low number, or do they all keep incrementing? A reset interval will indicate the system is resetting somehow.
Code: Select all
$ head -n2 * | grep -v Inter
==> rc_10.log <==
5083,0,,,,,,-0.17,-0.35,0.87,3,-2,1,,,,,,,,,,,,,,,,
==> rc_11.log <==
5083,0,,,,,,-0.22,0.44,0.87,-9,0,-1,,,,,,,,,,,,,,,,
==> rc_112.log <==
==> rc_113.log <==
5083,1495397973429,,,,,,-0.26,0.01,0.76,0,-2,-0,,,,,,,,,,,,,,,,
==> rc_114.log <==
5083,1495398110116,,,,,,-0.02,-0.91,1.02,19,2,2,,,,,,,,,,,,,,,,
==> rc_115.log <==
5084,1495398230167,,,,,,-0.12,-0.53,0.93,11,-2,3,,,,,,,,,,,,,,,,
==> rc_118.log <==
==> rc_119.log <==
5083,1495401391422,,,,,,-0.33,0.76,0.94,-24,-2,1,,,,,,,,,,,,,,,,
==> rc_12.log <==
5083,1495301311430,,,,,,-0.21,0.44,0.95,-6,-1,-2,,,,,,,,,,,,,,,,
==> rc_120.log <==
5083,0,,,,,,0.2,-0.71,0.87,17,-1,-3,,,,,,,,,,,,,,,,
==> rc_121.log <==
5083,1495401791082,,,,,,-0.07,-0.02,0.68,0,-3,0,,,,,,,,,,,,,,,,
==> rc_123.log <==
364,0,,,,,,0.08,0.02,0.82,0,-0,-0,,,,,,,,,,,,,,,,
==> rc_124.log <==
5084,1495404833147,,,,,,0.51,0.54,0.8,-19,-2,1,,,,,,,,,,,,,,,,
==> rc_125.log <==
5083,0,,,,,,-0.18,-0.65,0.95,9,1,0,,,,,,,,,,,,,,,,
==> rc_13.log <==
5083,0,,,,,,0.14,-1.08,0.95,28,2,2,,,,,,,,,,,,,,,,
==> rc_14.log <==
5083,1495301893201,,,,,,-0.35,-0.03,0.87,-0,0,-1,,,,,,,,,,,,,,,,
==> rc_15.log <==
5083,0,,,,,,-0.04,-0.02,0.94,1,3,0,,,,,,,,,,,,,,,,
==> rc_16.log <==
==> rc_17.log.csv <==
5083,1495304246588,,,,,,-0.19,0.29,1.24,-5,2,-2,,,,,,,,,,,,,,,,
==> rc_18.log <==
5083,1495304718012,,,,,,0.35,0.3,0.91,-14,-0,1,,,,,,,,,,,,,,,,
==> rc_19.log <==
5083,0,,,,,,0.1,-0.86,0.95,23,1,-0,,,,,,,,,,,,,,,,
==> rc_20.log <==
5083,1495306237415,,,,,,-0.34,0.08,0.99,-1,1,-0,,,,,,,,,,,,,,,,
==> rc_21.log <==
5083,1495306475138,,,,,,-0.2,-0.06,0.86,1,-2,1,,,,,,,,,,,,,,,,
==> rc_22.log <==
5083,1495307094611,,,,,,-0.19,0.73,0.95,-12,-2,-1,,,,,,,,,,,,,,,,
==> rc_23.log <==
5083,1495307224588,,,,,,-0.05,0.18,0.96,-11,1,0,,,,,,,,,,,,,,,,
==> rc_24.log <==
==> rc_25.log <==
5084,1495308124251,,,,,,0.36,0.51,1.14,-8,1,1,,,,,,,,,,,,,,,,
==> rc_26.log <==
5084,1495309299461,,,,,,0.07,0.87,1.02,-21,3,-0,,,,,,,,,,,,,,,,
==> rc_27.log <==
5084,1495309690553,,,,,,0.4,-0.39,1.12,6,1,0,,,,,,,,,,,,,,,,
==> rc_28.log <==
5084,1495310338749,,,,,,-0.25,0.95,0.93,-19,-0,0,,,,,,,,,,,,,,,,
==> rc_29.log <==
5083,1495310652703,,,,,,0.12,-0.72,1.12,15,-1,0,,,,,,,,,,,,,,,,
==> rc_30.log <==
5083,1495311091178,,,,,,0.06,0.42,0.97,-9,0,-1,,,,,,,,,,,,,,,,
==> rc_31.log <==
5083,1495311884131,,,,,,-0.35,0.02,0.92,1,-2,-0,,,,,,,,,,,,,,,,
==> rc_32.log <==
5083,1495312421688,,,,,,-0.16,0.93,0.94,-20,-1,-0,,,,,,,,,,,,,,,,
==> rc_33.log <==
5084,1495312828066,,,,,,-0.13,-0.0,0.54,-0,-2,-1,,,,,,,,,,,,,,,,
==> rc_34.log <==
5083,1495312969220,,,,,,0.52,-0.07,0.94,-1,1,2,,,,,,,,,,,,,,,,
==> rc_35.log <==
5083,1495313277296,,,,,,0.09,-0.52,0.93,15,-1,-0,,,,,,,,,,,,,,,,
==> rc_36.log <==
5084,0,,,,,,-0.07,-0.01,1.11,0,-1,-0,,,,,,,,,,,,,,,,
==> rc_37.log <==
5084,1495314230565,,,,,,-0.27,0.04,0.75,-0,-1,1,,,,,,,,,,,,,,,,
==> rc_38.log <==
5083,0,,,,,,-0.02,0.5,0.98,-10,-0,0,,,,,,,,,,,,,,,,
==> rc_8.log <==
==> rc_9.log <==
5084,0,,,,,,-0.24,0.07,0.52,0,-1,-0,,,,,,,,,,,,,,,,
Hi Brian, Try upgrading to the 2.11.0 firmware release, found here:
https://wiki.autosportlabs.com/RaceCapt ... e_Firmware
Your script seems sane, but I would personally replace it with something that triggered off of speed or battery voltage, just so you don't get needless logs. Examples:
https://wiki.autosportlabs.com/RaceCapt ... g_Examples
It does appear to be resetting.
After upgrading firmware, you could also pull the unit out and power it over USB with a USB charger or battery, and run it in your street car for a while. It's not Apples:Apples testing since you're not in the race car, powered over 12v with any sensors you have connected, but it could be a baseline test at least.
You can do conditionals and also do steps outside of onTick()...
My script is based off the example to turn logging on when the car is moving (I added a check so if I stop for a short time, like from a spin, it doesn't turn logging off)...
The example is at https://wiki.autosportlabs.com/RaceCapt ... g_Examples (the gps speed one).
if isLogging() == 0 and getGpsSpeed() > 0 then
startLogging()
end
would work and avoid any bug about starting logging over and over.
startLogging()
end
