RC Mk3 Antenna Connectors
ferrarif1
Post by ferrarif1 »
Looking to use the factory cellular aerial antenna on my BMW F80 M3, what is the connector style name used on the Mk3 so I can build/buy an adapter that mates up with the male version of the black connector here:
http://f30.bimmerpost.com/forums/attach ... 1444909333
Hi, It's a standard reverse polarity SMA connector.
One thing to confirm with the factory cellular antenna - ensure it is capable of 3G connectivity, and it's not just tuned for the 4G band. Do check even if it seems to connect with the factory antenna- it's possible it may connect even with a sub-optimal antenna, but may have significantly reduced performance and range.
Hope this helps!
