I have an RCP3 with v2.11.0 firmware and the OBDII/CAN adapter for my 2012 Porsche Cayman R.
I'm not seeing any CAN or OBD data, and the CAN light on the unit is not lit. I turned on OBD channels, CAN bus, and CAN mapping; all other settings are default.
So far, I've cycled through CAN bus speeds without success. I'm trying to use the CAN logger script to collect data and reverse-engineer the mappings.
Any suggestions on what to try next?
No OBDII / CAN data
Device log is below. Interestingly, it logs the same messages even if I turn off OBDII & CAN functions.
[CAN device] timeout rx CAN msg
[USB] Received CMD: {"getLogfile":null}
[USB] Received CMD: {"getStatus":null}
Waazzzup Jay!! You took the plunge!! Then immediately hit a wall!
All in good fun!
There are two can bus on the RCP3. You might wanna try changing the bus. To do this, change the following in the canbus logger script:
canBus = 1 or 2
https://wiki.autosportlabs.com/CAN_Bus_logger
Not sure this is completely your issue, but worth a shot. Don't forget to cycle through the baud rates on each bus.
All in good fun!
canBus = 1 or 2
Code: Select all
-- Log messages from CAN bus
-- be sure to set the correct baud rate in the CAN settings
-- change this to 0 for CAN bus 1, or 1 for CAN bus 2
canBus = 0
--this function drains all pending CAN messages
--and outputs messages to the log
function outputCAN()
repeat
id, ext, data = rxCAN(canBus, 1000)
if id ~= nil then
print('[' ..id ..']: ')
for i = 1,#data do
print(data[i] ..', ')
end
println('')
end
until id == nil
println('Timeout: no CAN data')
end
function onTick()
outputCAN()
end
setTickRate(30)
I put it under my driver seat. I had to tap power and also add an oil pressure sender, that side of the car made the most sense. Center of the car is rather difficult with stock interior. I also didn't drill the floor pan. Instead I poke through the foam in the carpet and secured the datalogger tightly.
Quick update:
Orange CAN data indicator went off again today while collecting data and no combination of settings would re establish the connection.
I plugged in my Durametric cable and it couldn't connect either. Turning the car off / waiting a few minutes/ back on didn't do the trick, so it must have a timeout window.
More research needed....
