I just wired up my ShiftX2. Night before a road trip to Watkins Glen of course. I wired it to CAN2 and spliced its power into the RCPmk3's power by soldering.
I'm using the provided shift ligth + alerts script and edited a few number to fit my needs. It seems to work fine for a few minutes on the road, but then suddenly it'll revert back to the start up light sequence where the strip of lights bounce left to right and change colors. It starts doing that for about a minute and then goes blank and is dead until I cycle power. I only went on one test drive, but this happened to me consistently through out the 20min drive.
I came back to the garage the plugged in the laptop with the car running. I set the shift light thresholds down low so i could easily see it work without revving too high. It seemed to work well. I ran for a good 15min in the garage playing with the alarms and shift thresholds and all seemed well. I then unplugged the laptop and ran the car for about 10min and things seemed ok.
I'm going to go for another test drive now.
Here is my script as it currently sits. There are no LUA errors.
Code: Select all
setTickRate(10) --10Hz
-- What CAN bus ShiftX2 is connected to. 0=CAN1, 1=CAN2
sxCan = 1
-- 0=first ShiftX2 on bus, 1=second ShiftX2 (if ADR1 jumper is cut)
sxId=0
--Brightness, 0-100. 0=automatic brightness
sxBright=0
sxCanId = 0xE3600 + (256 * sxId)
println('shiftx2 base id ' ..sxCanId)
--virtual channels
--addChannel("name",SR,prec,min,max,"unit")
speeddiff_id = addChannel("Speed_",10,0,0,160,"MPH")
gear_id = addChannel("Gear",5,0,0,5,"gear")
brakeg_id = addChannel("BrakeG",10,2,0,2,"G")
--global constants
first = 4.20
second = 2.49
third = 1.66
fourth = 1.24
fifth = 1.00
final = 3.46
tirediameter = 24.7
--global variables
rpm = 0
rpm_diff = 0
speed = 0
function updateSpeedDiff()
rpm_diff = getTimerRpm(1)
speed = rpm_diff*tirediameter*0.002975
speed = speed + 0.5 -- round because 0 prec. truncates
setChannel(speeddiff_id, speed)
end
function updateGear()
rpm = getTimerRpm(0)
local gearErr = 0.15
local gear = 0
if speed > 2 then
ratio = rpm/(rpm_diff*final)
if ((first - ratio)^2) < (gearErr^2) then gear = 1 end
if ((second - ratio)^2) < (gearErr^2) then gear = 2 end
if ((third - ratio)^2) < (gearErr^2) then gear = 3 end
if ((fourth - ratio)^2) < (gearErr^2) then gear = 4 end
if ((fifth - ratio)^2) < (gearErr^2) then gear = 5 end
end
setChannel(gear_id, gear)
end
function autoLog()
if speed > 10 and rpm > 500 then
startLogging()
end
if speed < 5 and rpm < 100 then
stopLogging()
end
end
function sxOnUpdate()
--add your code to update ShiftX2 alerts or linear graph during run time.
--Runs continuously based on tickRate.
--uncomment the below for Direct RPM on input 0
sxUpdateLinearGraph(getTimerRpm(0))
--update engine temp alert
sxUpdateAlert(0, getAnalog(0))
--update oil pressure alert
sxUpdateAlert(1, getAnalog(2))
end
function sxOnInit()
--config shift light
sxCfgLinearGraph(0,0,0,7000) --left to right graph, linear style, 0 - 7000 RPM range
sxSetLinearThresh(0,0,4000,0,255,0,0) --green at 3000 RPM
sxSetLinearThresh(1,0,5400,255,255,0,0) --yellow at 5000 RPM
sxSetLinearThresh(2,0,6800,255,0,0,10) --red+flash at 6500 RPM
--configure first alert (right LED) as engine temperature (F)
sxSetAlertThresh(0,0,215,255,255,0,5) --yellow warning at 215F
sxSetAlertThresh(0,1,225,255,0,0,10) -- red flash at 225F
--configure second alert (left LED) as oil pressure (PSI)
sxSetAlertThresh(1,0,0,255,0,0,10) --red flash below 8 psi
sxSetAlertThresh(1,1,8,255,255,0,5) --yellow flash 8-12 PSI
sxSetAlertThresh(1,2,12,0,0,0,0) --above 12, no alert
end
function sxOnBut(b)
--called if the button state changes
println('button: ' ..b)
end
---ShiftX2 functions
function sxSetLed(i,l,r,g,b,f)
sxTx(10,{i,l,r,g,b,f})
end
function sxSetLinearThresh(id,s,th,r,g,b,f)
sxTx(41,{id,s,spl(th),sph(th),r,g,b,f})
end
function sxSetAlertThresh(id,tid,th,r,g,b,f)
sxTx(21,{id,tid,spl(th),sph(th),r,g,b,f})
end
function setBaseConfig(bright)
sxTx(3,{bright})
end
function sxSetAlert(id,r,g,b,f)
sxTx(20,{id,r,g,b,f})
end
function sxUpdateAlert(id,v)
if v~=nil then sxTx(22,{id,spl(v),sph(v)}) end
end
function sxCfgLinearGraph(rs,ls,lr,hr)
sxTx(40,{rs,ls,spl(lr),sph(lr),spl(hr),sph(hr)})
end
function sxUpdateLinearGraph(v)
if v ~= nil then sxTx(42,{spl(v),sph(v)}) end
end
function sxInit()
println('config shiftX2')
setBaseConfig(sxBright)
if sxOnInit~=nil then sxOnInit() end
end
function sxChkCan()
id,ext,data=rxCAN(sxCan,0)
if id==sxCanId then sxInit() end
if id==sxCanId+60 and sxOnBut~=nil then sxOnBut(data[1]) end
end
function sxProcess()
sxChkCan()
if sxOnUpdate~=nil then sxOnUpdate() end
end
function sxTx(offset, data)
txCAN(sxCan, sxCanId + offset, 1, data)
sleep(10)
end
function spl(v) return bit.band(v,0xFF) end
function sph(v) return bit.rshift(bit.band(v,0xFF00),8) end
function onTick()
updateSpeedDiff()
updateGear()
autoLog()
sxProcess()
end
sxInit()
