Hi Brent,
Not sure if it was reported before, but I'm receiving a "Unfortunately, Race Capture has stopped." message when the app is finished by clicking the Exit option in menu. It happens every time in my Galaxy Note 4 and Galaxy S3.
Also, if I switch to another app and return to Race Capture, I get a black screen and have to manually kill the process and restart it.
Android APP - "app has stopped" message when Exit
In the 2nd scenario, does the black screen happen after you try to exit, then try to switch back to it ?
I tried to reproduce a simple scenario where I:
* launched the app
* pressed the home button
* launched another app
* pressed the button that brings up the list of active apps
* re-selected the RaceCapture app
The app came back with no issues.
Is this happening on app 1.11.0?
-Brent
* launched the app
-Brent
* launched the app
-Brent
* launched the app
-Brent
I'm seeing this same issue on 1.11 on a Samsung S8+
The menu with the exit button comes up, but the exit button is unresponsive.
Pressing the home button gets the app to the background, when I bring it back to the foreground the screen is black and I get a application stopped error.
Also had an issue doing the track walk at the autocross course. Got about 1/3 of the way through the course and the track mapping stopped and the restart button appeared. Did this on two course walks at about the same spot. Not sure if this is related or a separate issue.
Dennis
Dennis
You can scratch the course walk issue and attribute to operator error. Just did a walk in the neighborhood and figured out what I was doing wrong. Apparently, you can't add another sector or a finish too close to the last sector, during that time the only button highlighted is the re-start button. I think this is what I was seeing on track.d_gatorfan wrote: Also had an issue doing the track walk at the autocross course. Got about 1/3 of the way through the course and the track mapping stopped and the restart button appeared. Did this on two course walks at about the same spot. Not sure if this is related or a separate issue.
Dennis
