Over the last week i've taken the time to get the MJLJ installed on my 4 litre straight 6.
Since my car runs LPG i found it annoying that there was no ignition only ECU's out there, so when i found the MJLJ it was a very attractive option.
It is currently running in what seems to be a safe state of tune until i get the time to actually tune it properly. Very impressed with the overall ease of installation etc.
TO make my life easier, the EF Falcon's were already EDIS equipped using a slightly modified version of the US EDIS modules.
Unfortunately the EDIS module on my car is actually inbuilt to the ECU, so an EDIS module had to be sourced from the US, how ever my car already had the VR sensor, 36-1 tooth wheel and coil pack ready to go.
so essentially with 2 plugs i can go straight back to the factory setup (VR sensor and coil packs)
can't wait to see if i can pull a bit more performance out of the big 6
Ford EF Falcon (AUS) 4.0 6cyl
