Mapping Virtual AnalogX channels
PS14
Post by PS14 »
Trying to create a script that will take the front and rear brake pressures from AnalogX and create a virtual channel that shows the percentage of rear pressure vs total (f&r) pressure. what I want to see is percent of rear brake bias. I have the frt brake assigned to analog channel 3 input (named F_Brake), and the rear to analog channel 4 input (named R_Brake). does this script look like it will work?
--Create channel: "BrakeBias"
avgId = addChannel("BRAKEBIAS", 10, 0, 0, 100, "%")
function setChannel()
local a1 = F_Brake(4)
local a2 = R_Brake(6)
setChannel(avgId, (a2 / (a1 + a2))
end
function onTick()
setChannel()
end
jpf11
Post by jpf11 »
I'm not really familiar yet with how to get values from CAN channels. What are these "F_Brake(4)" and "R_Brake(6)" calls you're making? I would have thought you'd need some sort of getChannel function to pull those values (or did you do that outside the code you've posted here?).
PS14
Post by PS14 »
The F_Brake and R_Brake are the channel names is assigned in the CAN mapping section, so I thought maybe I could call them. but didn't work. I tried F_Brake(), F_Brake, getAnalogF_Brake(). then I tried calling the CAN inputs directly, but I don't think I have the setChannles formulas correct in the code (see below). I'm sure its doable, I'm just not a script master.
--Create Virtual Channels:
vfbrakeId = addChannel("vfbrake", 10, 0, 0, 1600, "psi")
vrbrakeId = addChannel("vrbrake", 10, 0, 0, 1600, "psi")
bbsId = addChannel("BrakeBias", 10, 0, 0, 100, "%")
function processCan()
id, ext, data = rxCAN(0)
if id == 935444 then
setChannel(vfbrakeId, data[7], 16, 40, -200)
setChannel(vrbrakeId, data[9], 16, 40, -200)
end
local a1 = vfbrake()
local a2 = vrbrake()
setChannel(bbsId, (a2 / (a1 + a2)))
end
function onTick()
processCan()
setChannel()
end
end
jpf11
Post by jpf11 »
I think firmware 2.13.0 supports getChannel by name, so if you mapped your channels using the CAN Mapping feature then you should be able to get their current values with a getChannel("NAME"), like getChannel("F_Brake"). You definitely cannot call a channel like a function by its name. So your lines in your first post's code would be:
local a1 = getChannel("F_Brake")
local a2 = getChannel("R_Brake")
PS14
Post by PS14 »
Thanks, i'll give that a try.
PS14
Post by PS14 »
Unfortunately, that didn't work. but i appreciate the suggestion.
end
function onTick()
setChannel()
end
You will need to ensure you're on 2.13.0 so you can use the getChannel() by name function, and you will also need to ensure you do a nil check, as the value may not always be available currently when requested (it's a function of the sample rate).
I would build up your script slowly to verify each step - if you put it all together and it doesn't work, then it's hard to identify where the problem is.
e.g.
function onTick()
local foo = getChannel("FOO")
if x ~= nil then println("got channel FOO " ..foo) end
end
Hope this helps!
PS14
Post by PS14 »
I'm on MK2 w/2.13.0. I have the F_Brake CAN channel on the left gauge and R_Brake CAN channel on the right gauge with the BrakeBias virtual channel in the center (on the three gauge dash). both CAN channels have data. I am sampling the AnalogX at 5hz so I should prob change the addChannel to match. so if I'm following, you suggest this?
avgId = addChannel("BRAKEBIAS", 5, 0, 0, 100, "%")
if x ~= nil then println("got channel BRAKEBIAS" ..bbs)
end
function onTick()
setChannel()
end
Not quite. x is not defined in your script, nor is bbs.
You want something like this. Note setting the tick rate to 50 at the top, and checking if things are nil.
setTickRate(50)
if a1 ~= nil then println("got channel a1" ..a1) end
if a2 ~= nil then println("got channel a2" ..a2) end
if a1 ~= nil and a2 ~= nil then setChannel(avgId, (a2 / (a1 + a2)) end
end
function onTick()
setChannel()
end
PS14
Post by PS14 »
for some reason it fails with the setTickRate(50) at the beginning. if i remove it or place it lower script runs, here's what i get: (the memory error is intermittent). and i just realized the error is "BrakeBias" but the channel name is "BRAKEBIAS", maybe i need to change that comment line.
got channel a111.600006
got channel a27.600006
[lua] Script error: not enough memory
[lua] Script error: [string "--Create channel: "BrakeBias"..."]:5.0: Channel not found!
[lua] Failure: Runtime Error
MK2 2.13.0/1.12.1
Correct, the name is case sensitive. Looks like you're getting closer!
