Summary: for a Subaru BRZ, CAN and ODBII mapping that are working using 2.12.0 firmware are not working in 2.13.5 firmware.
Details:
I am currently running 2.12.0 firmware in a MK2 in a Subaru BRZ. I have CAN mappings (5 single byte, 5 that are 2 byte) that are working correctly, and am reading RPM through ODBII. I would like to upgrade firmware so I can use the RPM channel in scripts.
With the 2.13.5 firmware, many of the CAN mapping are broken and the RPM ODBII mapping is also broken. I have played around with the mapping setting but cannot get good results. I mainly played around with the steering angle mapping, which is a 2 byte signed value, and works in 2.12.0 as big endian. In 2.13.5, these settings do not work, and I cannot find any set of bit or byte mapping that does work. As general symptoms, it looks like the sign bit, and higher order bits are not interpreted correctly - I get correct mapping for small positive numbers, but as soon as the sign bit or higher bits are set, then the mapping result if garbage.
I have attached the configuration that is working in 2.12.0. I can try to do a script that logs the raw CAN bytes and the mapped values if that would help.
Issue with CAN mapping in 2.13.5 firmware?
- 20180624.rcp.txt
- Racecapture Pro MK2 config with CAN mappings that work in 2.12.0 but not in 2.13.5
- (22.11 KiB) Downloaded 492 times
