RJ45 connector wiring convention for RaceCapture/Track?
GTIspirit
Post by GTIspirit »
What is the RJ45 connector wiring convention for the RaceCapture/Track MK2? Is this convention standardized across all Autosport Labs devices?
So it would be like this?
I assume the RJ45 CAN bus connection pictured above is from perspective looking into the device side female receptacle?
So the pin numbering to color convention is:
RJ45 Power, ground and CAN bus connections to RaceCapture/Pro EIA-T568B RJ45 cable color codes (check printing on the cable to confirm) Connection RaceCapture/Track MK2 (RJ45 cable)
Pin 8 +12v Brown
Pin 1 Ground Orange/White
Pin 2 CAN 1 High Orange
Pin 3 CAN 1 Low Green/White
Pin 4 CAN 2 High Blue
Pin 5 CAN 2 Low Blue/White
Hi, You can find it in the online docs:
https://wiki.autosportlabs.com/RaceCapt ... s_to_power
Same pinout as RaceCapture/Pro.
GTIspirit
Post by GTIspirit »
Yes, but that page only lists the wire colors, not the pin numbers. I suppose it assumes there is a coloring convention when inserting wires into an RJ45 connector.
The numbering in the picture above is from perspective looking into the RJ45 receptacle on the device, correct?
That is correct, ithe pinout is dentical to RaceCapture/Pro.
