Battery Voltage Channel Configuration? (RCP Pro Mk 3)
emdash
Post by emdash »
Not sure where this post belongs...
The Battery channel is present, and the channel does vary with engine RPM. But the value is off scale -- I'm seeing value of like 0.3 at idle - 0.8 with the engine racing a little.
Does this channel depend on power coming from the Molex connector to work correctly? I'm asking because in this case it's a big job to wire that up just to see what happens.
Or is this simply a software configuration issue? In which case I could use some info to how to configure it correctly.
The battery calibration might be off. Did you import a MK2 configuration into MK3?
You could try doing a factory reset to see if the battery voltage shows up correctly - in the latest app, check the firmware update page under setup, there's a button there to trigger a factory reset.
The battery voltage is read through 12v power - whether it is supplied via the molex connector or RJ45.
