Battery Voltage Channel Configuration? (RCP Pro Mk 3)
Posted: Tue Jun 18, 2019 11:11 pm
Not sure where this post belongs...
The Battery channel is present, and the channel does vary with engine RPM. But the value is off scale -- I'm seeing value of like 0.3 at idle - 0.8 with the engine racing a little.
Does this channel depend on power coming from the Molex connector to work correctly? I'm asking because in this case it's a big job to wire that up just to see what happens.
Or is this simply a software configuration issue? In which case I could use some info to how to configure it correctly.
