Haltech 1500 to Mk3
Aussieotto
Haltech 1500 to Mk3
Post by Aussieotto »
folks
I have a Mk3 and a Haltech 1300
I have the Haltech harness and I have connected
Haltech Mk3
Blue Can 2 high to Can 2 high
Blue/whit to Can 2 low
Orange white to And
12 v not connected
When I run the script to see if any data . nothin ( scripts been changed to use can )
Stop one can anyone confirm pinouts for Haltech elite to a Mk3 ?
Did you figure this out yet? You may want to double check:
* CAN high / CAN low wiring
* Termination is enabled on both ends (RCP MK3 is software controlled, under setup)
* Baud rate is identical on both ends
* CAN output is enabled with the Haltech
We have a generic CAN bus logger that will show if anything is being read from the CAN bus:
https://wiki.autosportlabs.com/CAN_Bus_logger
Hope this helps, please let us know what you find out:
