CAN bus controlled relay?
JustinDuBois
Post by JustinDuBois »
I'm looking for a simple simple device.
I want a relay (a switch I can control) using the CAN bus communications channel to open and close it. I would want to connect this to one of the Race Capture/Track CAN bus channels.
Has anyone located simple - in-expensive - CAN bus controlled electronics components like this?
Thank you
Justin
Re: CAN bus controlled relay?
You could try making your own with an Arduino + CAN shield + relay. Might be a fun project!
