engine temp and oil temp
Richard Tremblay
Post by Richard Tremblay »
I have install a racecapture/pro mk3 set up on my carburated 2.3l ford lima engine that go in my hydroplane. I am now triing to calibrate all my sensor. the problem that I have is that the engine temp and the oil temp sensors are indicating high temp on the dashboard while it is at room temperature. these sensors come from the discrete sensor kit that I bought to you. did I wired something wrong?
Re: engine temp and oil temp
Sounds like it. Best to check the wiring and ensure you have the pullup resistors connected, if it is a 2 wire temperature sensor.
