Dual Can hub, no connectivity to pro3
Swiftman_23
Post by Swiftman_23 »
I have a pro3, using rj45 to can adapter with dual can hub, analog x2, 4 sensor splitter with plug and play system. Pro3 connected to raspberry pi. Rpm gauge works great, but cannot get can bus to connect.
I have gone through the setup protocols listed meticulously 4 times. I am getting clean 12v on my can power, however my pro3 will not flash led indicating connectivity to can bus. any ideas? Thank you in advance
Re: Dual Can hub, no connectivity to pro3
Hi, You will need to set the baud rate for CAN 2 to 1 MB, not the default 500K you might have. AnalogX2 is 1MB by default.
Please let us know what you've found out after testing that.
