Heatmap not populating temp values
brendanmead
Post by brendanmead »
In the process of setting up a RaceCapture Pro MK2 - I am able to see my IZZE tire temp sensors in the raw channels screen and they have standard names: TireTmp_FR1, TireTmp_FR2, etc.... but I can't get them to show up in the heat map screen.
On the android app, I am able to change some options on the heat map screen such as number of channels per tire as well as channel names, which I left as default "TireTmp". In the desktop app, I do not have access to these same options.
Re: Heatmap not populating temp values
This has been corrected in the V2 beta app. You can test it on our Discord server - see the rc-v2-beta-testing channel to get started. https://discord.com/channels/7507352822 ... 6053761176
You will also need to update your CAN channel names to match the new presets (it removes the underscores from the channel)
brendanmead
Thanks. I'd like to try the beta app, but I can't get the discord link to work. I've tried a few different ways but am not able to open anything...
Here is an invite link https://discord.gg/UdB8N2A4
