MK3 Lights
aobrien1441
MK3 Lights
Post by aobrien1441 »
For some reason my system is acting "funky"...
Under normal operating conditions, what lights should be lit? The lights on the left (from Wifi to Power) are solid and the lights on the right (from CAN to GPS are blinking). Is this normal?
Re: MK3 Lights
Does it connect to the app at all?
If not, it could be stuck in bootloader mode. This can happen if the red button on the front is jammed inward too far. See if this is the case - if so, you can pull up on the edges of the button to unstick it.
It can also happen if there was a failed firmware upgrade - I don't think this is the case for you, otherwise you'd be mentioning it.
aobrien1441
Re: MK3 Lights
It does appear to connect to the app.
Have not attempted to run any firmware updates.
Will check on the red button.
Re: MK3 Lights
It could be the LED brightness spilling over to the other LED ports through the light pipes.
Does it happen if you only power it via USB and not 12v (rest of the car is turned off)?
Is it otherwise operating correctly?
