Analog sensor channel mapping
Nmunn
Post by Nmunn »
Want to get clarity on the analog sensor setup. There are 8 analog sensor HW inputs and in the analog sensor setup there are 9 "slots" to configure. Should I assume these are in sequence, top "slot" is hardware pin 1, slot 2, pin 2, etc? Also, there are 9 of these configurable slots so what is the last one? Is there a way to see how a channel is mapped?
Thanks in advance!
Re: Analog sensor channel mapping
For RaceCapture/Pro, Top channel starts at analog1. 9th (bottom) channel is the built in battery voltage.
The details of a particular channel will show you how it is mapped - raw, linear, or linear interpolation.
Hope this helps,
