Supercharged 440 carbureted. EDIS-8. Megajolt timing question
Flathead31coupe
Post by Flathead31coupe »
I have a supercharged 440 in a 65 dart. I switched over from points distributor to EDIS 8 and a mega Jolt Jr. I have a question on my old distributor. I was supposed to lock it out at 29° all the time. When I try to set up the mega jolt to do 29 across the board up to my rpm max. It has me to increase each bin 1° each time I change it. Is there any way to make the timing? 29° start to my max RPM
Re: Supercharged 440 carbureted. EDIS-8. Megajolt timing question
Hi, not sure what "Is there any way to make the timing? 29° start to my max RPM" means. Can you clarify?
The ignition timing chart literally outputs how it's configured; you can adjust the tablet by editing each cell as needed.
