Unfortunately, there are some errors when extracting the .bz2 file.
A command prompt log of the auto installation is attached.
I also tried the manual installation and received the same error.
Code: Select all
bzip2: (stdin) is not a bzip2 file.
tar: Child returned status 2
tar: Error is not recoverable: exiting now
It looks like there is a slight problem with the auto install script processing the URL for download.
I wonder if it has something to do with the format of the URL.
Code: Select all
sudo wget https://www.dropbox.com/scl/fi/68n7crkcaqzyrfv532g2r/racecapture_linux_raspberrypi_2.11.0.tar.bz2?rlkey=l8hqdj223yh6cgw8ej9d6vm3r&dl=1
Code: Select all
The RasPi treated each a bit differently, but extraction didn't work. Only when I direct downloaded from the RasPi browser did it work.
