Java Runtime Environment Problem
Martind
Post by Martind »
Hi, I have two problems running the program at the moment.
I have managed to get the program loaded onto my laptop. However the Java 2 Runtime Environment SE v1.4.2_06 Installer keeps telling me that my computer hasn't got enough memory to run the program. My machine has 32MB RAM - is that enough or do I need to buy more RAM? (I have 12.6GB free space too.)
Also when I open Megajolt, it says unable to open port COM1, unknown serial port. Any suggestions of ways around this problem?
Martin D.
flashrs1988
What operating system are
Post by flashrs1988 »
What operating system are you using?
32meg of ram is quite small?
Try shutting down any programs you are not using to free up as much memory as possible
Cheers
Steve
<img src="http://homepage.ntlworld.com/clark.rs/p ... rs1988.jpg" />
Oliver Sedlacek
Too small
Post by Oliver Sedlacek »
You don't say which OS you are running, but 128MB is a minimum in my opinion. The comms problem may or may not be related.
