Finished the build and ran into a few problems that I finally solved - the last one took a while
- Serial cable, from reading the forum, it is a common problem...
- Tried the Hyper terminal, everything appeared OK. Tried the mjdiag.exe app, and got the correct results for 'C' and 'S' - thanks to whoever wrote that! But nothing from the mjljTune-2.0.3.jar app....Strange, until I looked at in my java directory. I have j2re1.4.2_09 AND jre1.5.0_06 versions on my machine. Once I put the comms libs amd jars into the version 1.5 java directories, everything worked a treat!!!
Hope this might help others.
TimN
2.0l Pinto Green Cat
http://tigerkitcar.mysite.wanadoo-membe ... index.html
PC connection problems
