advice needed please !!
danncus
Post by danncus »
HI
i have been running a V2 board for a few months - with a TPS and sequential shift light(using shift light and outputs 1,2& 3.)
all has been very good.
until i tried to make the wiring perminent into the molex and shorten the wiring with heatshrink etc before using it at a sprint next sat.
when i powered it up all the LEDs lit up for a few seconds and then went out accompanied by a familiar burning smell!
on inspection Q6 has blown
questions
1. is it likley that the replacment of the transistor will restore the unit? (does anyone have a maplin ref #)
2. i can't find a wiring fault - can anyone diagnose what my have been at fault?
thanks
MartinM
If you're fairly sure it's
Post by MartinM »
If you're fairly sure it's Q6 that's let its smoke out, then remove it from the board.
Then I'd (re-)wire up the MJLJ from first principles up - ground, +12V, PIP and SAW - and verify it works OK. Then put your shift lights back on, one at a time - it should work except that PGM2 won't work. If that's OK, then replace Q6 and you should be OK.
Possible cause - pin 14 of the Molex directly to +12V would kill Q6...make sure you haven't connected any of the other prog. outputs or the shift light directly to +12v - that will kill each output transistor in turn!
danncus
thanks for the prompt reply
Post by danncus »
thanks for the prompt reply Martin
i found and fitted a 2222 transistor but it is still dead
i dont have my laptop at home
i also measured voltage on the tps in/output and got 1.8v and 12v
oh dear!
i have put the car away incase i do somthing i will regret!
is Q6 just switching pgm 2 ?
i should have left the £#%$£ thing alone!!
