Sharing VRS signal
4600cc
Sharing VRS signal
Post by 4600cc »
Suppose you have an ECU that uses VRS and 36-1 tooth gear, and you want to install EDIS + Megajolt and still use that same VRS sensor. How would one go about this? Is there a circuit that could be made to share this single VRS. I know that connecting VRS to ECM and EDIS in parallel won't work, since both ECM and EDIS send a refernece voltage to VRS.
I'm thinking of a circuit that would read VRS and have inputs for ECU and EDIS and madulate those inputs accordingly. Electronics is not my thing though, please somebody think of a simple solution. Just image you want to run two EDIS modules off a single VRS sensor.
AL
MartinM
...I know that connecting
Post by MartinM »
...I know that connecting VRS to ECM and EDIS in parallel won't work, since both ECM and EDIS send a refernece voltage to VRS...
I'm pretty sure that there's no voltage sent to a VRS - the VRS is just a magnet with a coil that responds to passing ferrous material and produces a sine wave ac voltage, magnitude depending on speed of the passing ferrous material - IIRC from a few tens of mVolts to a few tens of Volts
So I reckon you *could* supply two systems with the output of one VRS.
YMMV...
4600cc
Yes you right. A quick
Post by 4600cc »
Yes you right. A quick reference to Ford Fuel Injection & Electronic Engine Control proved that. So you think hooking EDIS and ECM in parallel to this sensor will not effect anything? Sounds sweet!!!!
MartinM
Gotta be worth a try....
Post by MartinM »
If the impedance on the VRS
If the impedance on the VRS inputs is high enough, it will be able to drive both.
Failing that, another option would be to use an op-amp or simple transistor amplifier.
